Add a TE 600 plunge base and transform your Bosch GKF 600 palm router, making a great addition to this already universal router. By adding this base to the GKF 600 motor you can achieve very controllable, precise routing. The plunge base has all the features you need: soft grip handles, smooth plunge action (max 55mm) with sprung lock lever, depth scale in metric and imperial, micro fine depth adjustment and 7-step turret depth stop. The cutter is visible at all times due to the wide opening of 54mm on the clear sub base taking a maximum bit size of 44mm. The motor body locks into the base with a clamp. This is a great accessory for your GKF 600.
Bosch
Bosch TE 600 Plunge Base for GKF 600 Router
| Plug Fitted | UK 3 pin plug |
| Model | TE 600 |
| Fine Height Adjuster | Standard Equipment |
| Plunge Stroke | 55 mm |
| EAN Barcode | 3165140754866 |
