The Einhell TP-ET 18 Li BL - Solo Palm Router has a powerful motor with variable speed control electronics, so it adapts perfectly to the task. Continuous milling depth adjustment and high quality aluminum construction ensure precise work. The edge router base also enables chamfering of edges.
Fitted with an ergonomic, soft grip for added comfort. A plastic base plate insert protects the work surface. There is also a spindle lock for easy tool change and an LED for optimum illumination of the work area.
Supplied with: 1/4 collet sleeve, 6mm and 8mm collets 1 x Parallel Stop, 1 x Compass Tip, 1 x Guiding Role, 1 x Copy Sleeve, 2 x Spanners and 1 x Extractor Adaptor.
Part of the Power X-Change series of tools, 3 Year Einhell Warranty, registration within 30 days required.
Powered by Lithium-ion rechargeable batteries with a battery management system for a long-life.
Supplied as body only (no battery or charger).
Specifications:
Collet diameter: 1/4, 6mm & 8mm.
No Load Speed: 10,000 – 30,000/min.
Lift Height: 40mm.
Max. Milling Cutter: 30mm.
Weight: 1.34kg.
Battery Voltage 18 V
Dust Extraction Outlet 35 mm
Sound Power Level LwA [Uncertainty K] 88.1 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 77.1 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 0.813 m/s² [1.5 m/s²]
Cutter Speed 10,000 - 30,000 rpm
Model TP-ET 18 Li BL Solo
Collet Size 1/4", 6 mm and 8 mm
Nett Weight 1.34kg
Warranty Einhell 3 Year Warranty on Tools & Batteries + 10 Year on Brushless Motor Warranty
EAN Barcode 4006825664300
