For power and accuracy, for easier, safer routing the Festool OF 1010 REBQ-Plus with LED Light, is in a class of its own. In a nutshell it is extremely versatile, excellently precise and very easy to handle.
The routing depth can be adjusted to the nearest tenth of a millimetre in seconds. The double-sided column clamp makes the router extremely torsionally rigid, guaranteeing perfect routing results.
With the rechargeable LED light ring around the working area, you can see the workpiece clearly and without any shadows. This is essential for achieving high accuracy in routing. This smart design lets you closely see the router cutter to improve your accuracy further.
This router allows easy one handed operation either with the Festool guide rail system or freehand.
Festool's Plug-It system with its detachable power cable enables the fast swapping of Festool tools or easy cable replacement. The new style Festool parallel side fence is easily adjustable for quick and precise alignment, as the central clamp features a fine adjuster and adjustable guidance jaws, free of any tools.
Supplied with 8mm and 1/4 collets, side fence, guide rail adapter, open ended spanner all packed in a Systainer SYS3 M 237 case.
Collets Supplied 1/4 and 8 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Sound Power Level LwA [Uncertainty K] 103 dB(A) [3.0 dB]
Corded or Cordless Corded
Cable Length 4 m
Sound Pressure Level LpA [Uncertainty K] 92 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 2.0 m/s² 5.5 m/s²
Motor Power 1,010 W
Plug Fitted UK 3 pin plug
Cutter Speed 9,500 - 23,000 rpm
Manufacturer Part Number 578004
Model OF 1010 REBQ-Plus
Fine Height Adjuster Standard Equipment
Nett Weight 3.2kg
Plunge Stroke 55 mm
Voltage 230 V
EAN Barcode 4014549436875
