The ZS-OF 1010 M Systainer is more than just a storage solution, this systainer streamlines your workflow and ensures that your tools are protected and ready to go!
The cleverly designed systainer contains versatile accessories, including guide rail adapters, copying rings, and base runners as well as space for your router cutters. All are held in designated spots, ensuring your tools and accessories are neatly organised and at your fingertips. Also included is a Micro Systainer SYS3 XXS, perfect for storing small materials, screws, and tiny components.
With the Guide Rail Adapter and support foot included, your router glides smoothly along guide rails, ensuring precise straight routing.
Need to create circles? The Trammel Unit allows you to route circles up to a diameter of 760 mm. Ideal for curved designs, decorative inlays, and circular patterns.
The Fine Adjuster feature lets you dial in the perfect settings for both the guide rail adapter and the trammel unit. Achieve pinpoint accuracy in your woodworking projects.
The Transparent Base Runner provides an unobstructed view of your workpiece. No more guesswork—see exactly where your router is cutting, even in intricate designs.
The Wide Base Runner ensures steady guidance along edges. Whether you’re working on tabletops, cabinetry, or custom moldings, your router stays on track.
Different Copying Rings allow reliability when routing with templates. The copying rings are precisely centred in the router’s base plate using the centring mandrel, achieving consistent results every time.
The unique Chip Deflector optimizes dust extraction when routing along edges for dust free routing And with Parallel Side Fence compatibility the extraction hood pairs seamlessly with the parallel side fence, ensuring dust-free operation and precise cuts.
From precision routing to seamless storage, the ZS-OF 1010 M Systainer is an intelligently designed system you can't live without.
Supplied with: Guide Rail Adapter, Fine Adjuster Fe-Fs/Of 1000, Centring Mandrel , Copying Ring D17, Copying Ring D24, Copying Ring D27, Copying Ring D30, Copying Ring D40, Base Runner Las-Of 1010 R, Support Afb-Of 1010 R, Trammel Unit Sz-Of 1000, Extraction Hood For Of 1010 R Parallel Side Fence, Chip Deflector, Systainer Sys3 Xxs 33, Systainer Sys3 M 187.
Manufacturer Part Number 578046
Model ZS-OF 1010 M
EAN Barcode 4014549437476
