The MICROJIG MATCHFIT CNC Workholding Kit is a versatile CNC clamping system designed to secure workpieces quickly and accurately during CNC machining. Using the innovative MATCHFIT Dovetail System, it allows users to create custom dovetail workholding tracks in a spoilboard for flexible clamp placement and reliable holding power. Its low-profile design keeps the work surface clear for machining, while a range of included clamps help prevent movement, lifting and vibration for improved cutting accuracy. Compatible with most benchtop CNC machines, this kit is an ideal solution for professional and hobbyist woodworking applications.
MICROJIG
| Web Attribute Set | Bench Dogs & Bench Fittings |
| EAN Barcode | 815267012020 |
