The MICROJIG MATCHFIT Dovetail Router Bit is a precision-engineered 14 degree router bit designed to create smooth, accurate dovetail tracks for the MATCHFIT clamping system. Ideal for jigs, fixtures and custom workholding setups, this dovetail groove cutter produces clean grooves in a single pass thanks to its unique built-in roundovers. The result is less sanding, smoother clamp movement and faster project completion. Available in multiple shank sizes, this jig router bit is a practical solution for woodworkers looking to create flexible, cost-effective dovetail tracks without the expense of traditional T-track systems.
MICROJIG
MICROJIG MATCHFIT Dtail 14°x1/2" Router Bit 1/4SHK
| Web Attribute Set | Dovetail Router Cutters |
| EAN Barcode | 815267011016 |
