Transform your Origin into a hands-free CNC powerhouse with BenchPilot. Whether you're batch-producing tenons, engraving large signage, or just want to give your arms a break, BenchPilot takes over the heavy lifting—literally. Clip Origin into BenchPilot and let it drive, so you can focus on the finer details of your craft. Then, when you’re ready to move, unclip and take Origin with you. It’s CNC, your way.
BenchPilot is the perfect companion for Origin users who want to streamline repetitive tasks without sacrificing precision. With real-time control, intuitive setup, and seamless integration with Shaper Workstation, BenchPilot makes Origin even more versatile—whether you're cutting horizontally, vertically, or somewhere in between.
BenchPilot drives Origin from 1 to 45 inches per minute using a belt-driven system. Adjust the feed rate on the fly with a tactile control knob and watch the cut time update in real time. The automatic feed control drives Origin from 1 to 45 inches per minute using a belt-driven system. Adjust the feed rate on the fly with a tactile control knob and watch the cut time update in real time. What's more, go from benchtop gantry to handheld CNC in seconds. BenchPilot gives you the flexibility to switch modes without missing a beat.
The timer display allows you to stay informed with Origin’s on-screen progress and time remaining, while BenchPilot is in control. With the Workstation’s vertical clamping face and optional Shelf Upgrade Kit, you can cut on-end or profile large parts with ease—operations most CNCs can’t handle.
No G-code required! If you know how to use Origin, you already know how to use BenchPilot. No complex software or programming needed. A dedicated emergency stop (E-stop) button gives you peace of mind when you need to pause or stop cutting instantly. Go from benchtop gantry to handheld CNC in seconds.
To Fit Router Shaper CNC Router
