With its smooth internal bore it minimises internal friction, which in turn ensures maximum airflow and suction. The hose is extremely flexible and with an equally smooth outer surface. Unlike traditional ribbed vacuum hoses, the Shaper hose will not catch or snag on a corner or the edge of your bench. The tapered 27/32mm connection fits snuggly in the Shaper’s extraction outlet, at opposite is 55/58mm taper for connection to your vacuum extractor. Made from antistatic material it prevents static build up caused by the waste passing through.
Length 2.5m.
Manufacturer Part Number SR1-250
Model SR1-250
Outer Diameter 32 mm
