This arbor enables 10mm bore metal centred polishing mops to be mounted in a power drill or flexible shaft. It has a 6mm shank to fit into the drill's chuck. Please note, when using a polishing mop in a drill or flexible shaft, it is recommended to use mops no more than 100mm in diameter.
Shesto
Arbor for 10mm Bore Polishing Mops
| Web Attribute Set | Polishing Mop Accessories |
| EAN Barcode | 5060030665872 |
