Axminster Diamond Pocket Sharpener
SKU: 103261
€4,95
  • Versatile, choice of sharpening surfaces, tapered for serrated blades
  • Durable diamond-coated stainless steel rod, double-ended
  • Pen-type aluminium holder with pocket clip
This diamond-coated, pocket-sized sharpening steel is double-ended. The overall length of the steel is 130mm, with an 8mm diameter. One end tapers to a point, designed for sharpening serrated blades. The other end is flat on one side and curved on the other with a groove for sharpening fine pointed objects such as awls or fishhooks. The anodised aluminium holder features a pocket clip at one end and a collet at the other. The collet firmly grips whichever end of the steel you decide to use. When not in use the steel slides neatly inside the holder for protection. This sharpener is suitable for use on a wide range of tools; knife blades (straight or serrated), secateurs, loppers, scissors, awls, darts, fish hooks and more.
Web Attribute Set Diamond Sharpening Systems
EAN Barcode 5052511091935
