Edge
Axminster Edge Aluminium Oxide Grinding Wheel - 200mm
SKU: 113809
£18.68
£15.57 Excl. VAT
  • Ideal for sharpening tools for clean, sharp edges
  • Softer bond, less chance of overheating the tool
  • 40mm wide, 200mm diameter, 15.88mm (5/8) bore
  • Available in 60 and 120 grit
White aluminium oxide grinding wheels have a slightly softer bond than standard grey grinding wheels, making them ideal for sharpening tools rather than heavy material removal. They cut freely with less heat build-up, helping to reduce the risk of drawing the temper from the steel and producing a cleaner, sharper edge.
Available in 60 grit for faster stock removal and reshaping, or 120 grit for finer sharpening and finishing, these wheels are 40mm wide, 200mm in diameter, and feature a 15.88mm (5/8) bore.
Grit 60
Wheel Diameter 200 mm
Wheel Width 40 mm
Web Attribute Set Replacement Grinding Wheels
EAN Barcode 5052511144679
