Axminster Green Polishing Compound
SKU: 105929
£2.98
£2.48 Excl. VAT
  • Green; first stage for ferrous if good condition
  • Best results with sisal or stitched mop (use on a leather strop)
  • First stage for poor condition non-ferrous
  • Cut 7; Colour 8
  • Bar size 100 x 35 x 20mm; weight 100g
Green compound is a versatile compound for use on steels and ferrous metal. If the piece is in reasonable condition, begin with the green on a sisal or stitched mop and then finish with blue compound. It is good used in the first stage for non-ferrous in poor condition with a stitched mop. The green compound is useful for rubbing onto a leather strop as honing compound.
Our compound bars are colour coded, making them immediately identifiable. Each one is a combination of a selected abrasive in a specific binder. Each colour has two reference numbers. The first denotes the 'Cut' or level of abrasiveness; the higher the number, the coarser the grit. The second number is the 'Colour' which relates to sheen; the higher the number, the shinier and glossier the result.
Green: Cut 7; Colour 8.
Bar size 100 x 35 x 20mm; weight 100g.
Web Attribute Set Polishing & Honing Compounds
EAN Barcode 5052511116331
