Axminster Pink Grinding Wheels
SKU: 75001
€26,00
  • Semi-friable grindstones
  • Especially suited to grinding fine edged hand tools
  • 150mm diameter, 31.75mm bore, 80 grit
Semi-friable grindstone suited to the grinding of fine edged hand tools where the risk of overheating needs to be avoided. They are more resistant to grooving when reshaping or heavy sharpening is required than the white aluminium oxide stones. Available in 150mm diameter 31.75mm(1.1/4) bore, 80 grit and two widths, 20mm or 25mm.
Grit 80
Wheel Width 20 mm
Web Attribute Set Replacement Grinding Wheels
EAN Barcode 5052511001361
