Axminster Professional
Axminster Professional Steel Slip Plate For Ultimate Edge
SKU: 105676
€4,95
  • Clips onto the platen of the Ultimate Edge Sharpening System
  • Covers the graphite slip plate, providing firmer surface
  • Helps when sharpening wide flat bevels
  • Easily removed after use
This simple piece of thin steel clips onto the platen of the Ultimate Edge Sharpening System and covers the graphite slip plate. While the graphite slip plate helps the abrasive belt move evenly over the platen when pressure is applied, there are times when a firmer surface may be required. This is especially important when sharpening wider flat bevels on plane irons for example. The steel slip plate is easy to remove after use.
Made in Britain Yes
Web Attribute Set Powered Sharpener Accessories
EAN Barcode 5052511114122
