Axminster Professional
Axminster Professional Ultimate Edge Twist & Fix Arbor
SKU: 105419
€51,00
  • Attach a mop/honing wheel to the Ultimate Edge Sharpening System
  • Mount each mop on its own 'Twist & Fix' one twist and it’s locked
  • Totally unique, offers virtually instant change between mops
  • Runs in forward or reverse
  • Makes polishing/honing process quick, safe and simple.
  • Additional 'Twist & Fix' mop arbors are available as single items or 3's
The Polishing and Honing 'Twist & Fix' Arbor allows you to attach a mop, felt wheel or profiling wheel to the Axminster Professional Ultimate Edge sharpening machine. The 'Twist & Fix' arbor is totally unique and offers virtually instant change between types of mops or ones with different compounds etc. It comes in two parts, a carrier with a 12mm shaft and the detachable 'Twist & Fix' mop arbor. The carrier bolts onto your Ultimate Edge sharpening machine (mounting hardware supplied).
The Twist & Fix arbor does just that, one twist and it’s locked in place on the carrier. The unique connection allows it to run in either direction of rotation: forward or reverse. The 'Twist & Fix' arbor carries the Ultimate Edge mops and honing wheels. Polishing mops, felt wheels etc should always be used in order, working from coarse to fine compound. With each mop etc mounted on its own 'Twist & Fix' arbor you can change in an instant, ensuring the polishing process is quick, safe and simple.
Additional Twist & Fix mop arbors are available as single items or in 3’s.
Rating Frequent Use
Made in Britain Yes
Intended Use Attach a mop/honing wheel to the Ultimate Edge Sharpening System
Web Attribute Set Polishing Mop Accessories
EAN Barcode 5052511109135
