Axminster Twist & Fix 100mm Sisal Polishing Mop
SKU: 105421
€14,00
  • More aggressive than a standard stitched mop
  • Use for first stage polishing on steel, aluminium alloys, stainless steel
  • Mounts directly onto the Ultimate Edge Twist & Fix arbor
  • Recommended for use with grey compound
These 100mm diameter stitched sisal mops have a 12mm bore for mounting onto the Ultimate Edge Twist & Fix arbor.
Sisal mops combined with the correct compound will polish out grinding marks caused from previous abrasive applications. They form the initial process for polishing steel and non-ferrous metals such as aluminium and brass.
Combined with grey compound, the sisal mop has a fast cutting action and removes scratches left by abrasives or grinding marks.
Sold in pairs, both need to be used together when used with the Twist & Fix arbour.
Made in Britain Yes
Web Attribute Set Polishing Mops
EAN Barcode 5052511109159
