Axminster Professional
Axminster Twist & Fix Mop Arbor - Pack of 3
SKU: 720623
€98,00
  • Pack of 3 additional mop arbors for Ultimate Edge 'Twist & Fix'
  • Have each mop on its own arbor for rapid changing
  • Makes polishing/honing process quick, safe and simple
  • Offers virtually instant change between mops
  • One twist and it’s locked runs in forward or reverse
The 'Twist & Fix' Mop Arbor simplifies and speeds the sharpening and honing process on the Ultimate Edge sharpening machine.
If you have a 'Twist & Fix' arbor fitted on your machine, additional mop arbors allow you to have a variety of mops, felt wheels or profiling wheels, ready to attach in an instant.
It’s best practice to use a separate mop for each different grade of polishing compound. The mops, felt wheels etc should always be used in order, working from coarse to fine compound. With each mop etc mounted on its own 'Twist & Fix' arbor you can change in an instant, ensuring the polishing process is quick, safe and simple. An additional mop arbor saves time and fuss as the polishing or honing process progresses.
Made in Britain Yes
Intended Use To allow you to have a variety of mops ready to attach in an instant.
Web Attribute Set Polishing Mop Accessories
EAN Barcode 5052511139934
