Axminster Universal Bench Grinder Stand
SKU: 340162
€81,00
  • Solid cast iron
  • Designed to support most bench grinders and lightweight machinery
  • Three-legged base, substantial 265mm x 185mm mounting platform
This robust pedestal grinder stand is designed to support most bench grinders and other lightweight machinery. Featuring a sturdy three-legged cast iron base with pre-drilled holes for secure floor mounting, it offers excellent stability. The central column is heavy weight steel tube, topped with a generous cast iron mounting platform measuring 265mm x 185mm.
Many Axminster grinders can be mounted directly. For larger models or other brands, simply add a thick MDF sub-base for a custom fit. The stand has an overall height of 784mm, making it a practical and a reliable addition to any workshop.
Web Attribute Set Grinder Stand
EAN Barcode 5052511012923
