Axminster Workshop
Axminster Wide Wheel for AWBGDL/AC150WSG Bench Grinder
SKU: 400074
€13,00
  • 40mm wide, 150mm diameter
  • 80 grit aluminium oxide
  • For the Axminster AWBGDL and AC150WSG wide stone grinders
A replacement 40mm wide 80 grit aluminium oxide wheel for use with the Axminster AWBGDL and AC150WSG wide stone grinders. 150mm diameter and a 12.7mm bore, insert included to fit 12.7mm (1/2") shaft. (31.75mm without the insert)
Web Attribute Set Replacement Grinding Wheels
EAN Barcode 5052511072330
