Einhell
Einhell TC-BG 150 Bench Grinder 150W 230V
SKU: 114112
€42,00
  • Versatile bench grinder for sharpening, sanding, and polishing
  • Dual wheels (coarse & fine) for multiple applications
  • Durable metal construction with smooth, low‑play shaft
  • Adjustable work supports and tool‑free spark guards
  • Stable operation with vibration‑absorbing rubber feet
The Einhell TC‑BG 150 Bench Grinder is a versatile grinding and sanding machine suitable for a wide variety of workshop tasks. Equipped with two grinding/sanding wheels powered by a single motor, it’s an essential addition to any workshed.
This double‑wheel grinder is ideal for sharpening scissors, knives, blades, drill bits, cutters, and chisels. It can also be used for derusting, deburring, polishing, and shaping wood, plastic, and metal workpieces. Whether carrying out minor touch‑ups or more demanding repairs, the TC‑BG 150 provides reliable performance.
Its robust metal housing ensures long service life, while large adjustable work supports make it easy to handle different applications. The ball‑bearing mounted shaft runs smoothly with zero play for precise results. Safety features include tool‑free adjustable spark guards and side‑closed guard hoods. Four rubber feet minimise vibration and keep the machine steady during use.
The grinder comes fitted with both coarse and fine wheels (K36/K60).
Specifications:
Input Power: 150W
No‑Load Speed: 2,980/min
Coarse Disc Size: Ø150mm (32mm inner)
Fine Disc Size: Ø150mm (32mm inner)
Weight: 5.89kg
Web Attribute Set Bench Grinders
EAN Barcode 4006825649888
