The Faithfull Triangular Diamond Sharpening Stone is a versatile and efficient solution for sharpening a wide range of blades and tools with minimal effort. Each of the three sides features a different diamond grit: 400 grit for rapid material removal, and 1,000 and 1,200 grit for refining and finishing a sharp edge.
Supplied with a durable plastic base fitted with non-slip pads, it provides excellent stability during use.
Diamond stones are suitable for sharpening carbon steel, HSS and tungsten carbide tools, and can also be used for working on glass, ceramic tiles and porcelain. They are effective when used dry or with water as a lubricant.
Ideal for sharpening knives, scissors, chisels, plane irons, cutting tools, TCT router bits and more.
