Each Scruff ball consists of a spherical shaped non-woven nylon mop made up of aluminium oxide abrasive discs. The shape and a certain amount of flexibility means you can use them on many different profiled shapes and surfaces. Available in three grades. Mainly intended for use on metals although some interesting effects can be achieved when used on wood. The most widely used applications are producing a satin or matt finish on metal, or smoothing and preparing the surface prior to final polishing with compound and cotton mops. Maximum recommended speeds of 5,000rpm. Eye protection must be worn.
Flexipads World Class
Flexipads Scruff Balls
| Grade | Medium |
| Web Attribute Set | Polishing Mops |
| EAN Barcode | 5055142013208 |
