Laguna
Laguna G8 Dual Speed Bench Grinder - 230V
SKU: 112934
€180,00
  • Designed for the edge tool grinding requirements of woodworkers and turners
  • 200mm x 25mm aluminium oxide wheels in 60-grit and 120-grit
  • Dual speed for fast waste removal and slower for finishing, with less overheating of tool
  • Two generously sized, adjustable grinding rests
  • Flexible LED work light fitted
The Laguna G8 Grinder, is engineered to meet high standards of precision, durability, and versatility, making it an indispensable addition to the woodworker or woodturners workshop.
With dual-speed capabilities, the Laguna G8 Grinder offers 1490 rpm for heavy stock removal and 2890 rpm for precise sharpening and polishing. Slower grinding does not produce a lot of heat when sharpening and reduces the chances of the edge of your tool overheating giving you more control.
The two extra-wide flat tool rests provide ample support for your tools, ensuring stability and accuracy during grinding. The adjustable tool rests, controlled by a lever and knob, allow for precise positioning, giving you optimal grinding angles and improved control.
Equipped with aluminium oxide wheels in 60 and 120 grit, this grinder delivers efficient material removal and a smooth finish, perfect for various grinding applications. The flexible LED light enhances visibility, ensuring better accuracy and safety in your work area.
Safety is paramount with adjustable spark deflectors and 3X magnifier-equipped eye shields, protecting you from sparks and debris while offering magnified visibility for detailed work. The heavy cast-iron base ensures stability and reduces vibrations, providing a solid and secure grinding experience.
Vibration reducing rubber feet are included to minimize vibrations, enhancing user comfort and reducing noise during operation. The mounting slots in the base allow for easy and secure attachment to a workbench, ensuring stability during use.
Maintain the grinding wheels so they are in optimal condition is very important to ensure consistent performance and longevity. The G8 is supplied with a diamond wheel dressing tool to dress the wheels and is stored in the holder on the back of the machine. This machine has precision bearings to ensure durability and reduce vibration for extended tool life.
Elevate your woodworking and woodturning projects with the Laguna G8 Grinder, a tool that combines power, precision and safety for the ultimate grinding experience.
Overall L x W x H 430 mm x 280 mm x 370 mm
Rating Home Workshop
Motor Power 370 W
Plug Fitted UK 3 pin plug
Web Attribute Set Bench Grinders
EAN Barcode 5052511140718
