Shesto
Polishing Kit for Steel & Stainless Steel
SKU: 503931
€42,00
  • Use in a power drill or flexible shaft
  • Produces a mirror finish on steel, stainless steel and ferrous metals
  • 3 x mops, 3 x polishing compounds, 1 x straight shank arbor
Used with a power drill or flexible shaft, this kit provides all you need to produce a mirror finish on steel, stainless steel and ferrous metals. The kit contains everything needed to carry out the process in three easy stages. Firstly, a 100mm sisal mop and grey compound, followed by the 100mm firm mop and pink compound. Finally, for a high gloss mirror finish, the 100mm soft mop and blue compound. The kit also includes a straight arbor with which to mount the mops in a drill chuck.
Web Attribute Set Polishing Mop Accessories
EAN Barcode 5060030669665
