Stitching produces a mop with a firmer face; a stitched mop's normal usage is in the first and second (if required) stages of the polishing process. The thickness is given in sections, each section the equivalent of approximately 13mm. The mops have leather centre washers for support and are for use on a tapered spindle. For best results use a separate mop for each different compound, mark each mop using a felt tip pen with the type of compound used. Store mops in individual plastic bags when not in use.
Shesto
Polishing Mops Stitched
| Mop Diameter | 100 mm |
| Mop Width | 13 mm |
| Web Attribute Set | Polishing Mops |
| EAN Barcode | 5060030665926 |
