Tools from Japan
Suehiro Flattening Whetstone - Coarse
SKU: 113303
€21,00
  • Flattens wet sharpening stones only.
  • Restores smooth, even surfaces on medium and finishing whetstones.
  • Helps maintain optimal sharpening performance.
  • Fast resurfacing with #100 grit using simple back‑and‑forth strokes.
This Whetstone Flattening Stone is designed exclusively for flattening wet sharpening stones and is an essential tool for maintaining the performance of your medium and finishing whetstones. Over time, regular use causes whetstones to become uneven or lose their smooth surface as metal particles and debris build up. By using this flattening stone with water, you can quickly restore a true, flat and clean surface, ensuring your sharpening stones continue to deliver consistent, accurate results.
The coarse 100 grit surface provides fast, efficient removal of high spots and wear patterns, helping you bring your stone back to its original condition with minimal effort. Simply wet both stones and use steady, back‑and‑forth strokes to refresh the surface. This flattening stone is sized for comfortable handling and built with durable materials to withstand frequent maintenance sessions.
The stone measures 206 × 53 × 27 mm and has an approximate weight of 550 g. As part of the manufacturing and finishing process, slight variations in size can occur.
Web Attribute Set Sharpening Stone Accessories
EAN Barcode 4966684014046
