Tormek
Tormek AX-40 Axe Jig
SKU: 111876
€44,00
  • Sharpen all types of axes with precision.
  • Achieve a concave or convex bevel.
  • Sharpen a flat bevel on the wheels side.
  • Easy to use with high-precision results.
  • Compatible with Tormek T-8 and T-4
The AX-40 Axe Jig is your go-to tool for sharpening all types of axes with pinpoint precision. It's incredibly user-friendly – simply flip it over to sharpen the other bevel for a perfectly symmetrical result. The robust composite jaws securely hold your axe and feature two stops for sharpening axe heads of various shapes and sizes. By allowing the jig to glide on the universal support between the two stops, you can achieve a convex bevel, ideal for specific applications. This jig's versatility makes it perfect for sharpening carving axes, carpenter's axes, outdoor hatchets, and more. One jig for all your axe sharpening needs!
Compatible with Tormek T-8, T-4, and older models with universal support.
Web Attribute Set Grinding Jigs
EAN Barcode 7392485002390
