Having found the profile best suited to your way of working, you need repeatability every time you sharpen. Using the TTS-100 setter and SD-186 gouge jig guarantees repeatability, if you can remember the settings. These labels attach to your chisel’s ferrule and record the jig setting, chisel projection and the hole to use on the TTS-100 to set the correct distance from the stone. So, next time you sharpen, the label will tell you how to repeat your favourite profile exactly. Comprises 9 labels and a short instruction leaflet.
Tormek
Tormek PL-01 Profile Labels
| Web Attribute Set | Grinding Jigs |
| EAN Barcode | 5052511100774 |
