Tormek
Tormek T-4 Original Sharpening System
SKU: 507158
€475,00
  • Compact, high quality sharpening system with 200mm wetstone
  • Sharpen your plane irons and chisels with a perfectly square edge
  • Sharpen hand tools, knives, scissors, woodturning and woodcarving tools
  • NVR switch, providing safety in the event of an interruption of power
  • Stainless steel shaft
  • SP-650 Stone Grader and AngleMaster included
  • Strengthened housing for improved sharpening results
  • Solid zinc, precision machined top incorporating the handle
  • 8 year warranty (5+3)
The Tormek T-4 incorporates, innovative, patented features that allows you to sharpen your tools to the finest edge. Firstly, the zinc cast top incorporates the key components of the main shaft, Universal Support and motor assembly resulting in superb accuracy as standard. Secondly, the Universal Support is held in two sleeves in the zinc cast top, meaning that the improved locking design and tighter tolerances will give even better results. Both designs give improved accuracy and precision for easy sharpening on the Tormek T-4.
The T-4 model is an incarnation within a long line of Tormek water-cooled grinding systems. In common with its larger sibling, the T-8, it is ideal for sharpening cabinetmaking hand tools, knives, scissors and woodcarving and turning tools. Like the larger machine models, the Tormek T-4 Original comes equipped with Tormek's Original Grindstone. It comes supplied with two useful accessories, the first of which is the SP-650 Stone Grader that can be used to keep the stone cutting efficiently as well as changing the surface from a (220g) coarse cut to (1,000g) fine. The equivalent of 2,500-3,000g can be achieved on the leather wheel. The second is the AngleMaster, an adjustable device used to set the correct angle for grinding plane and chisel blades. Magnets on the reverse side of the AngleMaster mean that it is easy to store it conveniently on the steel machine plate.
This is the first machine for some time to be supplied without a jig, so for instant sharpening, a jig of choice needs to be purchased from the many available, all of which will fit the Tormek T-4.
Also supplied is the unique Tormek Handbook, where all the information that is required to shape, sharpen and hone your tools to perfection can be found. The T-4 uses a powerful, industrial AC motor and the shaft supporting the wheels is made from corrosion resistant stainless steel. The 200mm(8) diameter stone has the Tormek EzyLock mounting system for fast stone changes without a spanner. Supplied with the SP-650 Stone Grader and SG-200 Original Grindstone with adjustable sharpening properties.
For more tips on sharpening please see Tormeks YouTube channel.
8-year warranty* (5 + 3) 5 years + 3 years when you register at tormek.com
*The warranty for the Tormek T-4 Original is 2 years when used for commercial, industrial, or educational purposes
Overall L x W x H 230 mm x 200 mm x 260 mm
Rating Home/Light Trade
Motor Power 120 W
Web Attribute Set Powered Sharpeners
EAN Barcode 7392485000426
