Tormek
Tormek T-8 Original Sharpening System
SKU: 102175
€820,00
  • The original and still the best wetstone sharpening system
  • Revolutionary fully cast housing for strength and accuracy
  • Micro adjustable for complete control of sharpening angle
  • Integral sleeves for support bar guarantees correct alignment
  • Screw lift rise and fall mechanism for water trough
  • Sharpens all types of steel, including high speed steel (HSS)
  • Includes upgraded SE-77 jig for precise 90 edges
  • 8 year warranty (5+3)
The Tormek T-8 sharpening system is the perfect answer to your sharpening requirements. For any professional or amateur needing a versatile, reliable and repeatable sharpening system, the T-8 should be on the top of your list. The T-8 has a 250mm x 50mm water-cooled grindstone and a 220mm x 31mm leather tyred honing wheel.
Powered by a quiet 200W motor, Tormek’s unique and efficient drive system maintains constant speed, even under load. Tools can be sharpened with the Supergrind wheel cutting towards or away from the edge.
The T-8 features a strong, cast-alloy casing. The mounting sleeves for the universal support are an integral part of the casting. The design eliminates the possibility of any misalignment between the universal support and the grinding wheel. The universal support bar has a micro-adjuster, which makes setting up or replicating a sharpening angle easy and highly accurate. The Advanced Water Trough features a screw lift mechanism. You can fit it, fill it and then by simply turning the knob, raise the trough to bring the water into contact with the stone. It makes removing the trough for emptying just as simple. The T-8 includes a magnetic scraper for efficient cleaning. The unit has an NVR safety switch with a strong waterproof cover.
The T-8 is suitable for use in education and other areas where an NVR switch is a necessity. The T-8 includes TT-50 Truing and Dressing Tool, SP-650 Stone Grader, WM-200 Angle Setting Guide, PA-70 Honing Paste and Dressing Oil for the honing wheel. In addition, there is a comprehensive handbook packed in a strong storage tray. The T-8 also includes the SE-77 upgraded jig for square edge tools. Its design has a movable side and fine adjustment. This ensures a precise 90 angle between your blade’s edge and side. It also offers the possibility to create a slightly cambered edge.
The Tormek wet-grinding method leaves a polished, burr-free edge without overheating the tool. Wet grinding significantly extends the life of your tools; it removes less material without affecting the temper of the steel.
For more tips on sharpening please see Tormeks YouTube channel.
8 year warranty (5+3 extra years upon registration)
Overall L x W x H 270 mm x 270 mm x 330 mm
Rating Trade/Professional
Cable Length 1.7 m
Motor Power 200 W
Web Attribute Set Powered Sharpeners
EAN Barcode 7392485000471
