Enhance your sharpening experience with the TF-2 Tilt Feet, a small accessory that makes a significant difference in water management. Designed specifically for the Tormek T-8, this clever addition slightly tilts the machine, ensuring that water dripping from longer tools is effectively redirected to the drip cover and back into the water trough.
This minimises water spillage and conserves the ACC-150 Anti-Corrosion Concentrate to deliver a cleaner, more efficient sharpening process. This accessory is simple to install, allowing you to quickly enhance your Tormek T-8's performance. Additionally, the TF-2 Tilt Feet enables you to operate the machine even without the grindstone. When not in use, it can be conveniently stored on the universal support. Compatible with the RB-180 Rotating Base.
Upgrade your Tormek T-8 with the TF-2 Tilt Feet and experience the benefits of improved water management and a more efficient sharpening process.
