Tormek
Tormek TNT-808 Woodturner’s Kit
SKU: 106730
€375,00
  • Sharpen turning tools with complete control
  • Packed in a high-quality storage case with foam insert
  • Contains Tornek's most popular and useful woodturner's jigs
  • SVD-186 for turning gouges and tool tips
  • SVS-50 for carving and lathe tools
  • TTS-100 angle and setting gauge for SVD-186 and SVS-50
  • SVD-110 support plate with Torlock
  • LA-120 profile impeller
  • MH-380 grinding machine cover
  • A comprehensive tuition manual
Packed in a high quality storage case with an opaque lid and foam insert, the TNT-808 is a comprehensive woodturner's sharpening jig set.
The TNT-808 innovative Tormek tool set for woodturners contains everything you need to shape and sharpen all turning tools. The jigs give you complete control over the sharpening process. The jigs ensure you are able to reproduce and repeat your preferred bevel angles and tip profiles time after time.
The Tormek TNT-808 set includes the following Tormek jigs and accessories: SVD-186 Universal Gouge Jig, SVS-50 Multi-Jig, SVD-110 Torlock Tool Rest, TTS-100 Angle and Setting Gauge, LA-120 Honing Wheel, MH-380 Protective Cover and tuition manual.
The set is compatible with Tormek T-7, T-3, T-4 and T-8.
For more tips on sharpening please see Tormeks YouTube channel.
Web Attribute Set Grinding Jigs
EAN Barcode 7392485007104
