It may be stating the obvious, but at some point the blades of the Veritas miniature tools will require sharpening and honing. This 1/3 scale version of the Veritas Mk1 honing guide is a natural extension to the Veritas miniature tool collection. This fully functional honing guide will help keep the miniature blades in peak condition.
The guide consists of a honing guide and an angle jig. The honing guide has a die-cast aluminium body that rides on a brass roller and accepts blades up to 19mm wide. The stainless steel clamping knob holds the blade against a pad in the guide. The angle setting jig has a 63mm long base and a 5-sided wheel that you can turn to a selected facet. You can use it to set your blade angle to one of the 5 most common bevel angles (15
It comes in a French-fitted leatherette presentation box. Made in Canada.
