Veritas
Veritas Saw File Holder
SKU: 504098
€47,00
  • Helps accurately control the angle of the file as you sharpen
  • Rotating collar for setting a positive or negative rake angle up to 30
  • 75mm wide protractor to the fleam angle up to 45 left or right
  • Protractor is marked in 5 increments
  • Collar with vernier scale marked in 1 increments
  • Anodised aluminium body, stainless-steel protractor and brass thumbscrews
  • 66mm overall length
  • Made in Canada
This well designed guide helps you accurately control the angle of the file as you sharpen. It has a rotating collar for setting a positive or negative rake angle up to 30. The 75mm wide protractor helps set the fleam (or bevel) angle up to 45 left or right. The protractor is marked in 5 increments and the collar has a vernier scale marked in 1 increments. An O-ring inside the collar provides light resistance to the vernier scale making precision setting straightforward. It has an anodised aluminium body, stainless-steel protractor and brass thumbscrews. Its overall length measures 66mm. Made in Canada.
Web Attribute Set Saw Sharpening & Guides
