Veritas
Veritas Tool Rest & Grinding Jig
SKU: 600321
€92,00
  • Replaces small rests supplied with most lower priced grinders
  • Suitable for 150mm(6) or 200mm(8) bench grinders
  • Can be quickly angled to virtually any angle for sharpening
  • Supplied with angle gauge for common bevels
This is a two part tool rest and grinding jig designed for mounting directly to the bench in front of either a 150mm(6) or 200mm(8) bench grinder. The 4 (100mm) table will straddle grinding wheels up to 1 (25mm) wide and can be set to the required angle using the setting gauge supplied. In the face of the rest there is a slot into which the optional straight grinding jig slides. This jig holds the tool firmly in position whilst grinding in order to give a perfectly straight edge. The positions of the jig clamping screws and the location pin can be altered to cater for different widths of tool and for setting a 30 angle for a skew chisel. The toolrest and the grinding jig can be bought as separate items or, if preferred, as a pair with a useful cost saving. As always with Veritas products this tool rest and its accessories are well thought-out and immaculately produced, and should prove to be of great use to the turner or general woodworker. Complete with full instructions.
Web Attribute Set Grinding Jigs
EAN Barcode 5052511074891
