Chestnut
Chestnut Melamine Gloss Lacquer
SKU: 310475
€17,00
  • Hardwearing finish; protects against heat and water
  • Can be used over a cellulose sanding sealer
  • Quick drying, dries to a gloss finish N.B. To buy this product you must be aged 18 years or over.
This finish will give protection against both heat and water. It can be used alone or, for better results, over a cellulose based sanding sealer. Several thin coats provide a superior finish. Quick drying due to cellulose base. The melamine dries to a gloss finish and can then be matted using 0000 Steel Wool, or brought to a gloss by applying wax with a pad of 0000 Steel Wool and buffing to a shine. If brushes are used clean in cellulose thinners..
Coverage 8 m to 10 m per litre
Application Method Brush Rag or Cloth Spray
Drying Time 5 minutes
Clean Up Cellulose Thinners
Available Sizes 500 ml
Web Attribute Set Lacquer, Paint & Varnishes
EAN Barcode 5060095030080
