Cascamite Accelerator is a hardener designed for use with Cascamite Powdered Resin Wood Glue. It significantly increases the cure speed of the mixed adhesive, achieving handling strength in approximately 25 minutes.
Well suited to urgent repairs, small assemblies, or situations where a fast turnaround is required, the accelerator allows glued joints to be worked on much sooner than standard Cascamite mixes.
Application
Apply mixed Cascamite Wood Glue to one mating surface
Apply the Cascamite Accelerator to the opposite surface using a brush
Allow the accelerator to become touch-dry
Bring the parts together and clamp
Under normal conditions, joints can reach handling strength in as little as 25 minutes.
Web Attribute Set General Woodworking Adhesives
EAN Barcode 5060584710417
