Upgrade or add a second bit to your Kreg 300-Series Pocket-Hole Jig with the Kreg Easy-Set Pocket-Hole Drill Bit, designed for fast, accurate drilling in 13mm, 19mm, and 38mm (1/2″, 3/4″, 1-1/2″) materials. This stepped bit - standard with 3-Series Kreg Jigs - features engraved thickness markings and a matching Easy-Set stop collar for quick, precise setup.
The included material thickness gauge makes selecting the correct setting simple, while the 6mm (1/4″) hex shank fits all standard quick-change chucks. Compatible with all Kreg Pocket-Hole Jigs for maximum versatility.
