The UJK Dowel Jig is a compact, precision-engineered solution for creating perfectly aligned dowel joints with speed and confidence. Designed for clean, repeatable drilling, it allows you to produce accurate dowel holes either dead‑centre or consistently offset from the timber edge, making it ideal for cabinet making, furniture construction and general joinery.
Whether used on its own or alongside the UJK Pocket Hole Jig, this dowel jig helps maintain precise alignment and reduces movement during assembly, resulting in stronger, more professional joints. A diamond-shaped viewing window allows you to line up accurately with your pencil marks, while the integrated drill guidance ensures every hole is drilled exactly where intended.
Attention to detail sets this jig apart. The supplied 6 mm lip and spur drill bit is purpose-designed to cut cleanly and efficiently, with clearance channels that guide waste away from the cutting edge. A wiper slot in the drill guide helps keep the bronze bushes clear, maintaining accuracy and prolonging tool life. While clamping is recommended, a rubber grip pad on the jig provides additional stability when positioning on the workpiece.
Manufactured in the UK, the UJK Dowel Jig is built from durable anodised aluminium and fitted with bronze Oilite bushes for smooth, quiet operation and excellent wear resistance. Compact, robust and easy to use, it is well suited to woodworkers of all skill levels who want reliable, repeatable results without complexity.
UJK is known for producing intelligently designed workshop accessories that combine precision engineering with real-world practicality. British made and workshop tested, UJK tools are engineered to deliver consistent results, long service life and excellent value for serious woodworkers.
The jig is supplied ready to use with a 6 mm lip and spur drill bit and a pack of 50 UJK fluted dowels (6 mm × 25 mm).
Web Attribute Set Dowelling Jigs & Accessories
EAN Barcode 5052511145584
