This split stop collar is designed to fit the shank of the UJK pocket hole drill bit, as well as other drill bits with 9.5mm (3/8
Internal diameter: 9.5mm, external diameter: 19mm, thickness: 9.5mm.
| Made in Britain | Yes |
| Intended Use | The process of joining wood at an angle, without visible fasteners. |
| Web Attribute Set | Pocket Hole Jigs & Accessories |
| EAN Barcode | 5052511137176 |
© Newhow Limited 2026.
VAT No: GB502514046
Company No: 16720753.
