The SprayCraft SP15K kit is the perfect introduction to airbrushing. The kit contains all the equipment you need, just add paint, ink or dye to suit your project. The airbrush has a 0.8mm nozzle and features a comfortable rubber grip. The snap-in paint jars allow you to change colour in seconds. The single action trigger is easy to operate and the external mix minimises cleaning. The kit comes with a can of propellant and hose. Alternatively, it can run off a small compressor using the adaptor supplied 15 to 50 psi operating pressure.
Kit contents: SP15 Airbrush, Propellant Adaptor, 300ml Propellant, Compressor Adaptor (1/8” BSP), 2x 20cc Bottles, 1.5m Hose.
Web Attribute Set Air Brushes
EAN Barcode 5060576967386
