The Fuji Spray 2QT Pressure Pot Backpack transforms mobility and productivity for professional sprayers, allowing hands‑free transport of a compatible 2‑quart pressure pot while working on large surfaces or in tight, hard‑to‑reach areas.
Designed as a dedicated backpack carrier, it supports extended spraying sessions by removing the need to carry or ground‑place the pressure pot. The adjustable harness distributes weight evenly across the shoulders, improving balance, comfort, and freedom of movement throughout the job.
Engineered for durability and ergonomic use, the backpack is ideal for professional finishing environments where mobility and efficiency are essential. Please note that this product is the backpack carrier only and does not include a pressure pot or hose assembly.
Fuji Spray is known worldwide for producing premium, high‑performance HVLP spray equipment trusted by woodworkers, furniture makers, decorators, and automotive refinishers. Their systems are engineered in Canada with a focus on precision atomisation, user comfort, and industry‑leading reliability.
Specifications
Backpack carrier for 2‑quart pressure pot systems
Adjustable shoulder harness for ergonomic support
Designed for use with turbine or compressor‑driven setups
Durable construction for professional workshop and site use
Quick and easy to fit and remove compatible pressure pots
This backpack is designed to be used in conjunction with the Fuji Spray 5432 2‑Quart Pressure Pot Assembly Kit (SKU 101564), which is supplied separately. When paired together, they create a fully mobile pressure‑pot spraying setup ideal for cabinetry, furniture finishing, onsite touch‑ups, and larger spraying projects.
Web Attribute Set HVLP Spray System Accessories
EAN Barcode 5052511146895
