The Fuji Spray 2‑Quart Pressure Pot Assembly Kit is designed to increase spraying efficiency by providing a higher‑capacity, lightweight material supply when used with compatible Fuji Spray HVLP turbine systems. By moving the material away from the spray gun, it significantly reduces hand and wrist fatigue while allowing longer, uninterrupted spraying sessions.
With a generous 2.25‑litre capacity, the pressure pot holds approximately twice the material of a standard bottom‑feed spray gun and over three times that of a gravity‑feed cup. This makes it ideal for spraying larger areas such as cabinetry, furniture, doors, or panels without frequent refilling.
The compact pressure pot design allows the spray gun to remain smaller and more manoeuvrable, making it easier to access tight spaces and spray at any angle, including upside down. Material flow remains consistent and stable throughout use, contributing to a smooth, professional finish across a wide range of applications.
Designed for use with 4‑stage Fuji Spray HVLP turbine systems, the 2QT Pressure Pot Assembly eliminates the need for a bulky external compressor when used with compatible equipment.
What’s Included
2‑Quart pressure pot with adaptor
1,800mm material fluid hose
Quick‑connect coupler
Pressure tube and check valve
Nipple caps
Important Usage Information
To use the 2QT Pressure Pot Assembly Kit, a 25ft standard air hose and a 2049F whip hose are required (not supplied).
When used with the 9600‑G GXPC Spray Gun, a 9060 L‑Fitting (Order Code 103702) is also required.
For increased mobility and hands‑free operation, the Fuji Spray 2QT Pressure Pot Backpack (SKU 113002, sold separately) can be used with this assembly kit. When paired together, they create a fully mobile pressure‑pot spraying solution ideal for onsite work, large projects, and extended spraying sessions with improved freedom of movement.
Web Attribute Set HVLP Spray System Accessories
EAN Barcode 612850054326
