Complete 285ml miniature cup assembly fits all Fuji turbine suction spray guns (past and present) except the Xpc and GT-X Gravity versions. Supplied with two extra cups and three heavy duty lids equipped with gaskets. This assembly is lightweight taking weight off the wrist. The small size allows access into confined areas such as cabinets, bookshelves etc. The cup is pressurised so the spray pattern is always perfect. You will think of many uses for these cups - storing paints and stains. It's also great for quick colour changes or any type of touch-up work. Guitar makers and auto touch-up are just two areas where this cup assembly is proving to be popular. If you are always spraying larger pieces such as kitchen cabinets, this cup set is too small for you - it would require too many fill-ups to make it practical.
Web Attribute Set HVLP Spray System Accessories
