Designed specifically for the VALOR H100 spray gun, these genuine Fuji Spray air caps allow you to tailor spray performance to the finish material and application. Available in 1.3 mm, 1.4 mm or 1.7 mm, each size controls how much material is delivered and how finely it is atomised.
Smaller air caps, such as 1.3 mm, are ideal for thinner clear coats where maximum control and a fine, smooth finish are required. The 1.4 mm option offers a versatile balance for general clear finishing, while the larger 1.7 mm air cap is better suited to thicker finishes or higher build applications, allowing material to flow more easily without excessive thinning.
Choosing the correct air cap helps improve finish quality, reduce overspray and ensure efficient, predictable results across different coatings and project sizes.
