At 202mm long and with a weight of only 900g, the GWS 12V-76 EC Professional is both compact and lightweight. The handy size allows you to carry out work almost anywhere, even in sometimes hard-to-reach areas. Thanks to the EC motor, the GWS 12V-76 EC has a very high power output for its size. The 76mm diameter disc offers a maximum cutting depth of 16mm. This versatile cordless tool can cut a wide variety of materials. Discs are available for cutting metal, wood, plastics and ceramics, giving it plenty of scope in many different trades. It reliably cuts cable ducts, threaded rods and edge strips for tiles, as well as tiles and tile grouts, pipes, hollow profiles and even perforated bricks and parquet flooring. The motor is at 90 to the body with the disc attached on the end of the spindle. This arrangement makes it easy to control replacing other tools such as the hand hacksaw. The EC motor does not require any maintenance and ensures the long life of the tool. Adjusting the disc guard is tool-less, just the push of a button. An electronic brake prevents overruns when switching the angle grinder off.
Supplied with 1 x carbide cutting disc and 2 x inox cutting discs. This is a body only machine and supplied without batteries or charger and part of the Bosch 12V battery family.
Battery Voltage 12 V
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 86 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 75 dB(A) [3.0 dB]
Web Attribute Set Cordless Angle Grinders
EAN Barcode 3165140813204
