Ultra thin metal cutting discs in 230mm diameters which cut faster than conventional discs by virtue of their reduced thickness. The amount of removed metal is reduced, increasing cutting speed and reducing the heat generated. Particularly suitable for stainless steel. Recommended maximum cutting speed is 6,650rpm for 230mm grinders. The 230mm discs are 1.9mm thick.
Bosch
Bosch Ultra Thin Metal Cutting Discs
| Disc Diameter | 230 mm |
| Web Attribute Set | Angle Grinder Discs |
| EAN Barcode | 3165140262859 |
