The DeWALT DEWDCG407N features a slide‑switch design and a brushless motor that delivers longer runtime, improved efficiency, and reduced maintenance. An electronic clutch helps minimise kickback in the event of a pinch or stall, while the mesh debris cover protects the motor by limiting dust intake. It also includes both a removable cutting guard and a grinding guard for added versatility. The side handle can be fitted in either of 2 positions for easy of use.
Comes with Side handle, disc wrench , grinding and cutting guard.
Supplied as body only (no battery or charger).
Part of the DeWALT 18V Li-ion XR battery family taking standard XR and Powerstack Batteries.
Specifications
Power Input: 840 W
No Load Speed: 9,000 rpm
Max Disc Diameter: 125 mm
Spindle Thread: M14
Weight: 2.172 kg
Length: 329 mm
Battery Type Li-ion
Corded or Cordless Cordless
Web Attribute Set Cordless Angle Grinders
EAN Barcode 5035048835005
