The Special Edition DeWALT DCG45MP1T McLaren F1 Angle Grinder delivers high‑performance grinding and cutting with an efficient 18V brushless motor engineered for power and durability. taking a 115mm disc it has electronic soft start to ensure smooth acceleration without kickback, while the mesh debris filter helps protect the motor by reducing dust ingress.
Designed for precision in tight areas, the compact gearcase offers improved access, and the rubber over‑mould grip enhances control and comfort during prolonged use. The two‑position side handle provides added stability, and built‑in safety features—including an electronic brake for rapid wheel stop and an electronic clutch to minimise kickback—ensure safer operation across demanding applications.
Supplied with cutting and grinding guards, a 5.0Ah McLaren F1 Li‑ion battery, charger, and branded carry case, this grinder is built for professionals who demand control, durability, and premium performance.
Part of the DEWALT 18v Li-ion XR battery family taking standard XR and Powerstack Batteries.
Specifications:
No Load Speed: 9,000/min.
Disc Diameter: 115mm
Spindle Diameter: M14
Weight: 1.8kg
Battery Capacity 5.0 Ah
Battery Voltage 18 V
Batteries Included 1
Battery Type Li-ion
Corded or Cordless Cordless
Web Attribute Set Cordless Angle Grinders
EAN Barcode 5054905333034
