The Einhell TE-AG 18 Li Angle Grinder 115mm (4 1/2) with Battery and Fast Charger provides a complete cordless solution for grinding and cutting applications around the workshop, garage and home. This is a high-performance 18V angle grinder that comes ready to use thanks to the 2.5Ah lithium-ion battery and a fast charger. It's an excellent choice for both new and existing Power X-Change users.
The Einhell TE-AG 18 Li cordless angle grinder is compact and dependable, making it well suited to a variety of cutting, grinding and finishing tasks, with a maximum cutting depth of 28mm. Its lightweight design includes safety features such as soft start, restart protection and overload protection for added confidence during use. The quick-adjust disc guard, ergonomic soft-grip surfaces and additional three-position handle offer excellent comfort and control. This cordless grinder boasts a durable aluminium gear housing plus a separate motor and gearing arrangement that delivers a smooth operation. It accepts standard 115mm discs for ease of use.
Included in the kit is an 18V 2.5Ah Power X-Change lithium-ion battery, engineered to deliver consistent cordless power and long-lasting performance. Featuring Einhell's intelligent Active Battery Management System, the battery continuously monitors operating conditions to optimise efficiency, extend service life and protect against temperature and voltage fluctuations. The robust housing helps withstand everyday jobsite use, while the integrated LED charge indicator allows users to quickly check the remaining battery capacity.
The Power X-Fastcharger completes the package by providing rapid, intelligent charging for all Einhell Power X-Change batteries. Advanced charging management continually monitors battery condition throughout the charging cycle to maximise safety and performance, while a dedicated refresh function can help recover deeply discharged batteries. A six-stage LED display provides clear charging status updates, and integrated wall-mounting points allow the charger to be stored neatly when not in use.
Einhell has built a strong reputation for producing reliable, innovative power tools that deliver excellent value for DIY users and professionals alike. Its versatile Power X-Change system allows a single battery to power an expanding range of compatible tools and garden equipment, providing a flexible and cost-effective cordless solution for a wide variety of applications.
Supplied with 1 x 18V 2.5Ah Power X-Change lithium-ion battery and 1 x Power X-Fastcharger. Part of the Power X-Change series of tools and batteries, 3 Year Einhell Warranty, registration within 30 days required.
Battery Capacity 2.5 Ah
Battery Voltage 18 V
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 86.1 dB(A)
Batteries Included 1
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 75.1 dB(A)
Web Attribute Set Cordless Angle Grinders
EAN Barcode 4006825602593
